Thermal Paste + Cooler... Please Help ? :)
27 Oct 2009
another question coming up... i've just after putting a grain size of thermal paste on my cpu and then the cooler ontop. i tried clicking the cooler into place but didnt think it was in right so took it off again to realign it.
now after coming back here to read the guide it tells me;
Note: If you ever remove the cooler it will break the seal created and the thermal paste will need to be cleaned off both the CPU and cooler and re-applied in the above fashion.
is this true even for the situation i've just created or will it be fine to just reattach the cooler to the cpu??
Weeeelll....
When you first stick thermal paste on you spread it out from a point such as a blob or a line. That helps prevent air bubbles.
If you spread it all over the heat spreader to start with or take the cooler off and reseat it you already have paste everywhere and that can't squeeze out trapped air, instead it will trap air.
The difference it makes isn't going to boil your processor but there we go. The air insulates by comparison to the paste which is meant to conduct heat.
Weeeelll....
the computer hasnt been turned on as of yet. literally still building the thing.
so what you are saying is that there will be air bubbles regardless that will conduct heat to the cpu and i would be best just starting over to make sure the cpu is well protected ?
Well no, trapped air won't conduct heat to the CPU but bubbles are worse than thermal paste for taking heat from the CPU to the cooler.
Ideally you apply paste, squish the cooler and CPU together and reapply paste if you take apart otherwise you're risking air being trapped between them.
