messiah khan said:
Not really. If both were applied correctly, you could expect to see at most a 3-4 degree difference.
I disagree. If both were applied correctly to a reasonably flat heatsink/block and cpu, the difference would be below the measurable tolerance of your motherboard. The actual amount of paste left between the block and cpu should be so tiny that any differences between the thermal properties would be practically irrelevant.
The only reason to get expensive paste is if you plan on leaving it unchanged for a long time, in which case the expensive paste will be better as it is less likely to dry out and cease to work correctly.
In the definitive online
review the best "paste" was water closely followed by toothpaste. The thermal pastes were all pretty much the same. Now I will grant you that the review is somewhat old but I firmly believe that the greatest advances in thermal paste recently have been in marketing and packaging rather than actual technical improvements.
So here's the typical situation that leads people to think their new paste is the greatest thing ever:
1) Overheating machine caused by dust build-up, a badly installed heatsink and some factory applied paste.
2) Machine is opened and dust removed. Heatsink is removed and fully cleaned including the base.
3) New super-duper paste is carefully applied after reading up on the web about how best to do it. The heatsink might even be lapped at this point (although this probably makes things worse).
4) The new heatsink is carefully re-mounted.
5) The computer is now "5 degrees cooler" all because of the expensive Antarctic Palladium 23.
Hmm. What about the dust removal? or the proper application of paste? or critically the careful mounting of the heatsink?
A bad heatsink mount will cost tens of degrees. The new paste may have made a fraction of a degree difference but the majority of the improvement came from simple attention to detail.
