** THERMAL PASTE MEGA DEALS **
rjk
rjk
OcUK Staff
8 Aug 2007
Arctic Silver Alumina Thermal Adhesive (5g) @ £2.99 inc VAT
Arctic Alumina Adhesive uses a layered composite of aluminum oxide and boron nitride. Arctic Alumina Adhesive is a pure electrical insulator, neither electrically conductive nor capacitive.
- Components:
A set of Arctic Alumina Thermal Adhesive consists of two syringes containing a total of 5 grams of adhesive (2.5 grams each of parts A and B) and a plastic reusable mixing wand. Approximately 3cc total adhesive.
Although lighter per set than Arctic Silver Adhesive due to its use of ceramics rather than silver, each set of Arctic Alumina Adhesive contains the same amount of adhesive by volume as a set of Arctic Silver adhesive and will cover the same area.
- Storage: Arctic Alumina Thermal Adhesive should be kept cold and away from UV light (sunlight and florescent lighting). We recommend refrigerating the unused material and allowing it to come to room temperature prior to use.
Was £6.98 Inc. VAT
Only £2.99 inc VAT.
ORDER NOW
SAVE £3.99
Arctic Silver 5 Thermal Compound (12g) @ £13.09 inc VAT
Introducing Arctic Silver 5 With its unique high-density filling of micronized silver and enhanced thermally conductive ceramic particles, Arctic Silver 5 provides a new level of performance and stability. Now available at Arctic Silver dealers worldwide, Arctic Silver 5 is definitely The New Reference. Arctic Silver 5 is optimized for use between modern high-power CPUs and high performance heatsinks or water-cooling solutions. Arctic Silver 5 uses three unique shapes and sizes of 99.9% pure silver particles to maximize particle-to-particle contact area and thermal transfer.
Was £20.39 Inc. VAT
Only £13.09 inc VAT.
ORDER NOW
SAVE £7.30
