Thermal Paste Removal/Application hi
30 Jun 2014
S-O-T
hi guys what best way/thing to remove thermal Paste Properly
also what is the Best Thermal paste to Use to redo the paste
(I'm planning to Change Motherboard)
I use nail varnish remover to get rid of the old thermal paste. I'd recommend Arctic Silver 5 as per RJC's suggestion. It's the only TIM I've used for years and I have no complaints about its performance.
You'll get all kinds of different advice on how to clean. But yes, personally I dab a little of the TIM cleaner on some kitchen roll then wipe off the top of the CPU IHS and base of the heatsink. Have a couple of cotton buds to hand for around the edges of the CPU IHS.
Double check you don't leave any residue behind.
I tend to use the Akasa cleaner, thermal paste I tend to use AS5 but everybody has there own personal favorite:
Akasa AK-TC TIM Clean CPU & Heatsink Cleaner
Arctic Silver 5 Thermal Compound (3.5g)
Exactly what I used yesterday (and 40+ times before that!)
IPA or nail varnish remover (acetone) + cotton buds will do the job fine, IPA is circa £2/ltr. Application I tend to use the plastic bag method for compound and again i've used AS since it launched - I probably still have some original stuff kicking about.
I use the Arctic Silver remover, although it's not needed I like using it. Then AS5 as i have done for years, works perfectly for me.
+1 on the Akasa TIM Clean. I've got a tube of Arctic Cooling MX-4 which has been great the few times I've used it.
Raises an interesting question, does this stuff go off?
