Thermal Paste spreading
6 May 2009
I took this from a site about applying thermal paste to CPU...
'set your heat sink in place, making sure that you go directly down, not on an angle because that will remove a lot of TIC from the core, and you’ve just spend 10 minutes correctly spreading it on, and there’s a precise amount on, you don’t want to remove a lot of TIC from the core by moving the heat sink around. Set it directly on top, slightly rotating it to get any air pockets out, but not moving it side to side, only on one axis.'
However on all the heatsinks i have ever owned they never just go on if you put them on straight. I have to tilt them to get one side of the clips on then force it down on the other.
Is there anyone else who is terrible at installing heatsinks? I think if i had a watercooling rig, i would be dead within the hour
Those Intel clips should be banned from use! They are a flaming nuisance. Its only whenever you have used a good mounting mechanism that you realise just how bad they really are.
Oh and yes, as above, depending on the type of paste used, spreading is not always the best way to use it.
On S939 AM2 and AM3 my coolers have usually needed clipping on one side then the other.
Using the rice in the middle technique on my Scythe Kama Angle this didn't go well recently. Reseated it, spreading it myself with a credit card to ensure thin and very even coverage and I've knocked 3°C off my load temps.
And they always describe them as quick and easy to fit :mad:
I was thinking about this the other day, whats the effect on the paste when installing a Corsair H50-1 as you have to twist the pump as you you lock it into place :confused: I thought about trying to hold the pump in the correct position and then fitting the locking ring, but to be honest I haven't got the room in my case for the extra set of hands that would be required to carry out this operation. Has anyone got any ideas.
My H50 will be arriving on monday or tuesday. I will take my motherboard out my case to install it (will have to anyway to fit backplate)
if you spread it make sure you dont put it right at the edges as when you place your cooler on it it spreads and can go off the edge
Personally, i just put a rice grain sized drop on the cpu, whack the heatsink on and the rest does itself, ive tried the spreading method in the past, made no difference whatsoever.
