- 22 Apr 2009
- northsea most of the time
I've just realized i'm out of my artic silver 5 for my cpu and have ordered more, but is this the best or is there better?
Thermal Grizzly Kryonaut I believe.
Its one of the better ones without going to something specialise like liquid metal type :S most thermal pastes are really close in realworld results though.
EDIT: I'd be wary of comparing AS5 results with other pastes based on most of the common roundups as they persist in ignoring Arctic Silver's application notes and applying it wrong - manually spreading it in the style that many of them do can very much compromise it's performance albeit only by 1-2 degrees. *bangs head against wall*
*Re-reads a popular 2015 roundup - bangs head against wall again*
The difference will be single degrees, I'd get the best value stuff.
For me it is gelid gc extreme. I've used mx-4, EK ectotherm, Arctic silver 5, ic diamond.
It has been the best so far. Not only this but it is very cheap aswell.
Thermal Grizzly is the king of the pastes!! Use this and you cant go far wrong.
Just ordered the Kryonaut after your recommendation. I will let you know if I get lower temps than the MX-4 I have been using.
Would like to see your results as some have said its no better than other pastes on the market
