Thermal Paste
14 Nov 2006
Newcastle, England
im waiting for my tuniq tower to be delivered
do i need to apply the thermal paste on the fan and cpu?:eek:
its my first time [virgin paster] :(
on my Thermalright SI-128 instructions it says to apply the thermal paste on the heatsink and cpu which worked well.
but uselly you only need to apply the thermal paste on the cpu.
Using the compound that comes with the tuniq apply a straight line of compound about 4-6mm long and when you place the tower on the cpu rotate it 45 degrees either way and then secure it. Thats exactly what i did and i have idle temps of 25-27 degrees so happy :).
