Thermal sensors on my Lian LI controller
Don
23 Oct 2005
North Yorkshire
Hey,
How do I attach the thermal sensors to the cpu, hdd and sys? how do they attach and what ''bit'' to?
This is for my Lian Li LCD thermometer I got off OCUK!
Thanks
andybtsn said:
Hey,
Thanks
With the TR3 there are 3 pieces of thermal tape, you need to possition the sensor and then stick it down with the tape.
HHD position on Hard drive stick down with thermal tape
SYS position anywhere you like, i have mine stuck to the mother board tray, and stick down
CPU Position on your heatsink or on the edge of the CPU if you can, DO NOT put it between the CPU and Heatsink as this will damage it. Again mine is resting inbetween the fins of my heatsink
