Thermalright 140 bw/haswell
How is it looking?
Do try and rotate it (make sure RAM is in 2+4th slot away from the CPU for maximum clearance) but if it hits the RAM then you leave it as it is.
Oh here's the other thread...
If you have it exhausting out the top it'll be fine. It'll work that close but it won't cool as efficiently.
No that'd be much better, if the fan at the top is an outtake then face it so the fan from the CPU is facing the outtake.
