Thermalright Deals!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
Get a load of these prices!
Great cooling properties and now amazing prices to boot! Talking of boots, you should fill yours with these :p
Thermalright Archon CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM3) @ £35.99 inc VAT
Armor style heatsink fin array, with mirrored copper base, elevates heatsinks overall quality. Large heatsink fin array provides dissipating area of up to 150*125mm, making complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory heat spreaders are avoided. Six sintered heatpipe design, all heatpipes are nickel plated, to slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the CPU. Supports Multiple-Platforms, and can be used on Socket 1366/1156/775 Platform, and AM2/AM3 Socket. For Intel sockets pressure is adjustable (40~70 lbs.) Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance). Fan-clips are compatible with both 140mm and 120mm fan. The Archon package includes a tube of CF III Thermal paste, to provide the best combination for use with Archon.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 806g (excluding fan and mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Was £44.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Thermalright Venomous X Silent CPU Cooler (Socket 775/1156/1155/1366/AM2) @ £32.99 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs. pressure system for Intel CPU user only), and have a more efficient and secure mounting. Include AMD Socket AM2/AM3 Bracket system. Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including FDB 600RPM ultra low noise Fan Cover set x2 and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
Heatsink Dimension
- Size: Length 127mm x Width 63mm x Height 160mm
- Weight: 755 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe *6 units
- Copper base: C1100 pure nickel plated copper base, with ultra-shine mirrored surface.
Fan Spec
- Dimension : 120 x 120 x 25mm
- Bearing Type : FDB (Fluid Dynamic Bearing)
- Rated Voltage : 12.0 VDC
- Operating Voltage Range: 10.8~13.2 VDC
- Rated Current: 0.130 Amp +10% MAX /0.11AMP
- Rated Power: 1.56 watt
- Rated Speed: 600 RPM ± 10%
- Airflow: 30.5 CFM
- Noise Level: 13.1 dB/A
- Life Expectancy: 60000 HOURS AT 40°c / 65%
- Net weight: 156 GRAMS
- Connector: 3 pin
Was £44.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Thermalright MUX-120 Black CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) @ £26.99 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Four sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Include Thermalright X-Silent series 120mm PWM Fan (600~1300RPM) Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Dimension: L133 x W58 x H160 mm
- Weight: Weight: 590g without fan ; 670g fan included
- Fan Rated Speed: 600~1300RPM
- Noise Level: 17~25 dBA
- Air Flow: 26.6~57.6 CFM
Was £40.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Thermalright Venomous X Black Edition CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366/AM2/AM3) @ £34.99 inc VAT
All new patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775 only). Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including 2 sets of 120*25mm fan clips & 140*25mm fan clips and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Compatible with Socket 1366/1156/1155/775 & AM2/AM3
- Heatpipe: 6mm sintered heatpipe x 6 units
Was £45.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Thermalright Shaman Graphics Card Cooler (GTX 460 / 470 / 480 / 5870 / 5850 / 4870 / 4850) @ £39.98 inc VAT
World’s First VGA cooler that supports the compatibility with 14cm fan with the dissipating area of 140mm * 130mm. World’s First VGA cooler with 8 * 6mm heatpipes, easily cools the hottest VGA in the Market. All new installation methods, provides easy mounting and gives better overall compatibility. Supports both 12cm or 14cm fan. Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance). Multiple support back-plate, to provide the best protection for your GPU. Mirrored Copper base, with quality craftsmanship.
- Supports GTX460/GTX470/GTX480/HD5870/5850/4870/4850
- Dimension: Length 160mm x Width 132mm x Height 38mm
- Weight: 500g (Excluding fan and Mounting brackets)
- Heatpipe: 6mm heatpipe*8 units
Fan Specifications:
- Dimention: Length 160mm x Height 140mm x Width 26.5mm
- Weight : 140g
- Fan speed: 900~1300RPM (PWM)
- Noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Connector)
Was £50.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
That Shaman is stupid cheap now. It supports the newer range of Cards too though including 6950/6970 and the 500 series. Paid £55 for mine.
I'm getting itchy feet with the silver arrow, I pre-ordered one to arrive about a week back and the date keeps moving further and further back, now its well into October. I just can not bring myself to paying £70 for a Noctua
yea the noctua should be at £65 no idea why they bumped it to £72 they are only going to lose sales especially when there's a new d14 killer coming from noctua and a revised new edition d14 with better ram clearance.
The black vx is at a very good price, would have been perfect for the second rig im working on, had to settle for a standard coloured TRUE from mm instead.
