HR-02
Silver Arrow
Thermalright is also readying a gargantuan single-block tower CPU cooler, the HR-02. Measuring 110 (L) x 140 (W) x 160 (H) mm, this cooler makes use of nickel plated copper heatpipes, aluminum fins, and tips the scales at 1.1 kg. Heat is conveyed to the 32 aluminum fins using six 6 mm thick heat pipes. The fins are punched in places to increase turbulence and area of dissipation. Although it doesn't ship with any fans, there are two sets of 120 mm and 140 mm fan retention clips included, along with a tube of Chill Factor III TIM. All current CPU sockets are supported. The HR-02 will reach stores soon.
Silver Arrow
Thermalright is readying a new CPU cooler modeled around the twin-block tower design that is getting some takers these days, the Silver Arrow. This cooler uses two aluminum fin blocks that dissipate heat from the CPU, with air circulated by two 140 mm TY-series fans. Heat is conveyed to the two blocks by four U-shaped 8 mm thick nickel-plated copper heat pipes. The fans spin at 500-1300 rpm, with noise-levels of up to 21 dBA. All current CPU sockets are supported, including LGA1366, LGA1156, AM3/AM2(+), and LGA775. Pricing is yet to be known.
