Thermalright Hyper Vision help
1 Mar 2024
Leeds
So i have a Thermalright Hyper Vision and the sereen keep reloading over and over, i have found it dosent play nice with L-connect and i use this to control my fans.
it because there both pulling system info over USB and L-connect win's
i fond a fix to disable L-Connect in Services and it did work, now the screen works fine but i have no fan control... not good
so i would like to disable the Thermalright and stop it from pulling info in services but i cant find the little bugger, dose any one have any idea what it would be called.
all i want is the screen to display a gif, not system info.
Any idea's? or is it going back
If using l-connect 3
Try L-connect 2
Or vice versa
There's also free fan control software
Called fan control
I had some success with it controlling usb connected fans
Yeah i find L-connect to be a PITA
With other similar software running
If i don't stop signal rgb running before opening
L-connect it will just say controller not found
I just set the lian li fans to a fixed rpm in L-connect in the end
Which it does remember so I don't need to use L-connect anymore
to be honest i love it, but didnt hand anything other than L-Connect
ive been reading online not that the Thermalright Vision coolers are having a lot of problems with most system tracking software
TBF when it comes to softwear i love the corsair coolers, so i suppose the one i just ordered is better.
just a little niffed off as i sold a 3 months old AC III cooler when the LCD one came...
