Either return it or lap it - lapping is good so just do that
Incidentally I'm seriously considering buying one of these - when you get it on, let us know how it performs
(also, what cpu etc are you running?)
Have a look at the following:
http://www.xbitlabs.com/articles/coolers/display/thermalright-ifx14_6.html
The first sample they received seem to have same problem as yours, and their quick test shown that the cooling does suffer because of it.
See if you can fix the issue yourself (without breaking anything), otherwise you best RMA it. The Thermalright IFX-14 is a very effective cooler (well heatsink) according to the xbit review, provided that it is not "faulty"...
While googling this issue, it seems some people suggest that Thermalright intentionally made the ifx-14 base slightly curved to provide better contact with the centre of the cpu.
Never lapped mine, never placed it on a flat surface to check either. Fit it as per instructions and it should be fine, if it's not then sort a return.
