- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
We are launching Thermalright cooling back at OcUK.
Pre-order now as the first batch will be limited stock.
Thermalright Venomous X Black Edition CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366/AM2/AM3) @ £56.99 inc VAT
All new patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775 only). Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including 2 sets of 120*25mm fan clips & 140*25mm fan clips and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Compatible with Socket 1366/1156/1155/775 & AM2/AM3
- Size: Length 127mm x Width 63mm x Height 160mm
- Weight: 755 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe x 6 units
- Copper base: C1100 pure nickel plated copper base, with ultra-shine mirrored surface.
Only £56.99 inc VAT.
ORDER NOW
Thermalright Venomous X RT CPU Cooler (Socket LGA1366/LGA1156/LGA775/AM2/AM3) @ £56.99 inc VAT
All new patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775 & AM2/AM3). Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including FDB 1300 ultra low noise Fan Cover set and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
Heatsink Dimension:
Fan Spec:
- Dimension : 120 x 120 x 25mm
- Bearing Type : FDB (Fluid Dynamic Bearing)
- Rated Speed: 1000 RPM
- Airflow: 38.9 CFM
- Noise Level: 15.8 dB/A
- Life Expectancy: 60000 HOURS AT 40°c / 65%
- Connector: 3 pin
ORDER NOW
Thermalright Archon CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM3) @ £59.99 inc VAT
Armor style heatsink fin array, with mirrored copper base, elevates heatsinks overall quality. Large heatsink fin array provides dissipating area of up to 150*125mm, making complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory heat spreaders are avoided. Six sintered heatpipe design, all heatpipes are nickel plated, to slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the CPU. Supports Multiple-Platforms, and can be used on Socket 1366/1156/775 Platform, and AM2/AM3 Socket. For Intel sockets pressure is adjustable (40~70 lbs.) Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance). Fan-clips are compatible with both 140mm and 120mm fan. The Archon package includes a tube of CF III Thermal paste, to provide the best combination for use with Archon.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 806g (excluding fan and mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Only £59.99 inc VAT.
ORDER NOW
Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) @ £59.99 inc VAT
4 X 8mm sintered heat-pipes effectively take away excessive heat from the CPU when overclocked, Nickel Plated heat-pipes, slower Oxidation and deterioration of the heat-pipes, provide longer period of Thermal conductivity. Double fin design , each side with 147*103mm heat dissipation area, can be used with 12 or 14 cm fan ( fan clips included). Special Arrow fin design, which allows cool air to pass through and take heat away rapidly, effectively provide cooling for the cpu. Support Multiple-Platforms. Can be used on Socket 1366/1156/775 Platform, and AM2/AM3 Socket. Including two 160*140 Ultra low noise PWN fan. With the compatibility of up to 3 fans at a time.
- Cooler Dimension: Length 147mm x Width 123mm x Height 160mm
- Cooler weight: 825 g (excluding BTK and Fan)
- Heat-pipe: 8mm Sintered Heat-pipe*4 units
- Cooler Base Material: C1100 Pure Copper with Nickel Plating.
- Fan Dimension: Length 160mm x Width 26.5mm x Height 140mm
- Fan Speed: 900~1300 RPM (PWM)
- Fan noise level: 19dBA
- Fan Airflow: 69CFM
ORDER NOW
Thermalright MUX-120 Black CPU Cooler (Socket LGA775/LGa @ £47.99 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Four sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Include Thermalright X-Silent series 120mm PWM Fan (600~1300RPM) Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Dimension: L133 x W58 x H160 mm
- Weight: Weight: 590g without fan ; 670g fan included
- Fan Rated Speed: 600~1300RPM
- Noise Level: 17~25 dBA
- Air Flow: 26.6~57.6 CFM
Only £47.99 inc VAT.
ORDER NOW
Thermalright HR-02 Passive CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) @ £57.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Fanless design for low-noise operation. Proprietary through holes on fins for efficient ventilation. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including 120*25mm fan clips & 140*25mm fan clips and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Compatible with Socket 1366/1156/775 Socket AM2/AM2 (optional - if you buy the mountking kit)
- Size: Length 110mm x Width 140mm x Height 160mm
- Weight: 860 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe 6 units
Only £57.98 inc VAT.
ORDER NOW
Thermalright Shaman Graphics Card Cooler (GTX 460 / 470 / 480 / 5870 / 5850 / 4870 / 4850) @ £49.99 inc VAT
World’s First VGA cooler that supports the compatibility with 14cm fan with the dissipating area of 140mm * 130mm. World’s First VGA cooler with 8 * 6mm heatpipes, easily cools the hottest VGA in the Market. All new installation methods, provides easy mounting and gives better overall compatibility. Supports both 12cm or 14cm fan. Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance). Multiple support back-plate, to provide the best protection for your GPU. Mirrored Copper base, with quality craftsmanship.
- Supports GTX460/GTX470/GTX480/HD5870/5850/4870/4850
- Dimension: Length 160mm x Width 132mm x Height 38mm
- Weight: 500g (Excluding fan and Mounting brackets)
- Heatpipe: 6mm heatpipe*8 units
Fan Specifications:
- Dimention: Length 160mm x Height 140mm x Width 26.5mm
- Weight : 140g
- Fan speed: 900~1300RPM (PWM)
- Noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Connector)
Only £49.99 inc VAT.
ORDER NOW
Thermalright TY-140mm Silent Fan (Fits 120mm fittings) @ £10.99 inc VAT
PWM fan, provides simple and easy adjustment of fan speed with the latest ETC IC. Seven Silent Torpedo Blades - “submerges”, gives most quiet and efficient airflow. Enhanced Hyper-Flow Bearing (EHFB) - to ensure consistent and stable rpm, prolonged lifetime of usage. Aerodynamic body–Less friction around the edges and give more centered and concentrated airflow. 12 cm mounting hole–allows installation on the 12 cm dimension, so will be compatible with most coolers without having the need to buy extra kit for 14cm fan.
- Fan Dimensions : L160mm x H140mm x W26.5mm
- Fan Weight : 140g
- Fan Speed : 900~1300RPM (PWM)
- Sound Level : 17~21dBA
- Airflow : 28.3~74CFM
Only £10.99 inc VAT.
ORDER NOW
ORDER NOW
Heatsink Dimension:
Fan Spec:
- Airflow: 38.9 CFM
- Connector: 3 pin
ORDER NOW
Fan Specification:
- Weight: 140g
- Airflow: 56~73CFM
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Fan Specifications:
- Weight : 140g
- Noise: 19~21dBA
- Airflow: 56~73CFM
ORDER NOW
- Fan Weight : 140g
ORDER NOW
