THERMALRIGHT SI-120 OR SCYTHE NINJA PLUS
Permabanned
10 Jun 2005
ok i have narrowed my chose for new cpu cooler down to SI-120 or the Ninja. what does everyone think? whcih is the best? what is the best fan (LED if possible) to go with them? i want to o/c a lot whats the best for this?
Cheers
Nick
I saw a chart in a thread over on overclockers.com when I was researching into which HS to get. At the time it was pretty much a toss up between the Ninja or the Thermaltake Big Typhoon.
The reviews arnt always that accurate and which coolers best will depend on case airflow to a certain extent but the ninja will destroy the si120 with similar fans. Sometimes the BT is better than the ninja and some reviews say BT and some say ninja - just comes down to case airflow. The ninja is more setup to have air being exhausted staight out back of case
