- 20 Feb 2009
- Ashton-Under-Lyne
I'm trying to pick the fans for my new build, which will be watercooled via 2x360 rads & I've come across both these as what look to be decent options at a reasonable price (£20+ per fan is just ridiculous IMO).
Some reviews I've seen say the Arctic is better, some the Thermalright, so I'm stuck for choice.
I like how the Arctic 0%PWM actually turns them off, as I'd like to run my PC as close to passive as possible when general browsing etc, but pretty much any fan would be practically silent @minimum RPM anyway.
The Arctic is rated at better static pressure, but the review at Hardware Canucks, taking nosie equalised performance on an AIO puts the Thermalrights as performing better.
If it makes a difference, I was considering push/pull on both radiators, so I can run all fans with as little noise as possible, whilst maintaining airflow. This makes the Thermalrights at less than 1/2 the price very atractive, if I'm buying 12 fans!
Does anyone have any experience with either (or even better, both) of these fans (especially on radiators) that can give their opinions?
