Thermalright True Spirit 140 - Bargain cooling potential
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have a price drop on the Thermalright True Spirit 140 coolers at the moment.
First up is the Thermalright True Spirit 140 which has seen a drop in price, also arriving today we have the new BW version.
This is an epic cooler for the money and easily fits alongside memory with taller heatspreaders.
both coolers have a comprehensive socket compatibility list, and as usual with all Thermalright products, the quality is no less than excellent.
Thermalright True Spirit 140 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £34.99 inc VAT
Ultra style heatsink fin array, with copper base, elevates heatsink’s overall quality. Large heatsink fin array, provides dissipating area of up to 150*125mm, make complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory spreaders are no issue. The cooler is supplied with one Thermalright TY-140 PWM fan, ultra low noise at 21 dBA at max rpm (50cm testing distance)
Fan-clips are compatible with both 140mm and 120mm fan.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 771g (including fan and pads. excluding mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Was £39.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Thermalright True Spirit 140 BW Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £34.99 inc VAT
ULTRA style heatsink fin array, with copper base, elevates heatsink’s overall quality.
With the max width of 55mm, tall memory spreaders are avoided.
Support Multiple-Platforms. Can be used on Socket 1366/115x/775 Platform, and AM2/AM3 Socket.
Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance)
• Dimension: L155 mm x W53.4 mm x H170 mm
• Weight: 605g
• Heat pipes: 6mm heatpipe x 6 units
• Fin: T = 0.4 mm ; Gap = 2.0 mm
• Fin Pcs: 44 + 6 = 50 pcs
• Copper Base: C1100 Pure copper nickel plated
• Motherboard to Fin: 39 + 8 = 47 mm
TY-140 FAN Spec
• Dimension: L152 mm x H140 mm x W26.5 mm
• Weight: 160g
• Rated Speed: 900 - 1300 RPM
• Noise Level: 17 - 21dBA
• Air Flow: 28.3 - 73.6 CFM
• Connector: 4 Pin (PWM Fan connector)
ORDER NOW
Hard to beat at that price - if I was looking at building a new rig that would be a must purchase right there ...
