Thermalright V1 Ultra...
1 Sep 2004
Northants
Im just wondering if any knows whether the Thermalright V1 Ultra will go on a X850 XTPE PCI-E, or perhaps someone has already put one on theres?
Any major problems with fitting it? And will it reduce the temps on my video enough to warrant shelling out the cash for it?
Cheers
Apparently its a complete and utter pain to fit, according to most reviews. Its a good cooler but is it worth the hassle when you could just get a VF-900 and have that fitted in 2 minutes...
You're a finer man than me if you can install a vf900 in 2 mins. But in all fairness even if you don't know what you are doing you can probably fit one in 20 mins or so on a clear surface.
