ThermalRight XP-120 (Socket 754/939/478) Heatsink
9 Jan 2005
Stoke-On-Trent
Will this clip on or will I need to take my mobo out of my pc to remove the heatsink holder? My socket is 939 mobo is in sig.
I can't be bothered removing the whole mobo again.
You need to remove the plastic bit thats mounted around the socket and fit the one they supply... Wont work without it.
Sorry.
Sam C
You do need to remove the standard mount but it just screws into original backplate so i didnt need to remove board on asus premium or dfi expert. You should be able to the same on your board
I thought the same, but when I unscrewed mine it slipped slightly... Thus necessitating board removal :(
Cheers,
Sam C
I had XP120 + Panaflo 120mm fan on my old Asus A8N-SLI Deluxe mobo.
But when I changed to the A8N32 I was not able to fit the XP120 to it - as the Heatsink was touching the NB/SB Heatpipe Sink above the CPU.
Replaced it with a Scythe Ninja :)
