thermaltake aguila troubles
29 Oct 2006
Cardiff, wales
hi guys...
ive got my new thermaltake aguila case here, and in the manual it has a little addendum showing you where to mounts 3 bits of plastic to stop the mobo touching the case...
now the big one is simple, but from the small picture i cant figure where the 2 small bits go...
anyone got any ideas??
thanks
i hope you can see it.. yes it really is that bad in real life :(
I have made it a bit clearer using a pic i found on the net.
i'd say they go here roughly, under that drive cage malarky, or as far across as the mobo reaches
i guess i will have to wait for the mobo to get here...
it wouldbt be such a problem if there wasnt 2 little threaded spigots exactly where the pic says to put them :(
