Thermaltake Armor A30 LAN Gaming Case CPU Cooler Question
I doubt an Artic Cooling Freezer 7 is good enough for decent temps at 4Ghz on an older i3, and I doubt it would fit in such a low profile case... Stock Intel cooler will fit but I would deffo not wanna run 4ghz with that either.
You will probably have to go with a good low profile cooler.
i got the cooler as part of a bundle from ocuk with a 4.2ghz overclock so i hope it will be ok at 4 lol.
Yeah i didnt think it would fit, just was hoping to not have to buy another :)
Any suggestions for a good low profile cooler?
Joker which fan did you go for in the end?
Ive just bought the same case so im looking for a good cooler also, i mainly use the rig
for gaming.
Got an intel closed loop cooler but theres no chance that will fit because of the rad :(
An also got a Asksa Venom an that thing aint even worth trying squeeze in there lol.
