Thermaltake Armor Jr. Installation
25 Oct 2006
Hey everyone,
I have a power supply out of this case http://support.packardbell.com/uk/item/index.php?m=home&pn=PB13217801
That i am attempting to put into my thermaltake armor jr. just to test until i get my power supply tommorow - http://overclockers.co.uk/showproduct.php?prodid=CA-009-TG
But when i have it put in, and line up the top screws there is about 1cm gap between the hole for the bottom screws and the actual screw hole on the case and vice versa.
Am i doing something wrong or is it just not compatible with my case?
Also will the tagan fit that i am getting?
Thanks,
Stopsign
One out my old PB was a FSP. I moved to a tagan but will have to move the P4 machine out my mambo case back to its orginial case to make room for my opty 144..
