Thermaltake armour case front panel problem
18 Sep 2007
I've just bought an aluminium thermaltake armour case connected everything and tryed to turn on but nothing happened. I have tested the motherboard and PSU in a different case and they both work fine. i have narrowed it down to the power switch on the front panel. has anyone else had this problem, is there a way to rectify this?
I have contacted overclockers just wanted to know if anyone has had this with this case
You can short the two pins on the motherboard to elimate the switch. I think the unit pulls out from the front, so you should be able to get to the switch
