- 10 Jun 2005
na not say ul to you talking bout the guy before your comment
Panaflo M1A 120mm fan, Thermalright XP-120.nick_lerwill said:what fans + cpu cooler you got to get such a good ratio
bbreezeuk said:has anyone overclocked with the thermalright si-120 (AMD)
Like i've said 3 times before, it's the Panaflo M1Anick_lerwill said:nice man, what fans that? does it come with SI-120?
I've got quite a poor clocker AFAIK, so at the moment i'm sat at 2.75ghz with 1.5v going through it. Idling at the moment at this (Ignore the voltage reading, it is actually 1.5v going through it):bbreezeuk said:what temps are you getting with you OCed 3700
I've got one 120mm SilverStone FM121 in the front of the case sucking air in and one 120mm Coolermaster LED in the back of the case sucking air outnick_lerwill said:oh right sorry yea looks good may invest in that fan aswell if you recon its good and quiet. how many case fans you got going there?
I'm using a Coolermaster Centurion 532 case, i had a crappy case before this which could take 4 80mm fans, the noise was unbearable as was the poor CFMnick_lerwill said:class i really want to upgrade to a 120mm fan cause my case just has room for 2 80mm fans at front 2 80mm fans at back and 1 80mm on top
A random name said:I've just got a Panaflo M1A fan this morning, and from what i've used so far this thing is very very quiet for the amount of air that it pushes. It's double width so it pushes more air with less speed i guess, but it's an excellent fan
Aye, only thing is did you notice major vibration issues when the fan is at full pelt?Amidar said:Glad it arrived safely.
