Thermaltake cases
7 Jan 2006
Having a look on Thermaltake web-site i see they now do the following model
Armor or Kandalf with a 25cm fan side panel
When are OC going to stock them ?
I can not really comment as I have not used one with the side fan yet, but I would imagine it would be 2/3 deg lower than the case without the fan.
Fans can never be big enough!
It is more if the gaming case manufacturers get the point on why fans get bigger. Push the same amount of air at LOWER volumes. Why we went to 120mm from 80mm.
But these push air/noise on a bad ratio! Almost all high ish end 120mm fans push more air per db than the huge gaming case style fans do! Pointless!
If these were 20db and 40cfm or something then I would be jumping up and down as they would be perfect for silent PC's, they however don't and make a racket (well the gaming ones of 140mm+ I have seen in action) if they go wrong you can't replace them either.
Just a gimmic, in 12 months time we will be, what was that craze about the big fans all about :confused:
