- 17 Jun 2016
Im planning my fan purchase and decided to do double 480mm rads in push-pull and aim for an ultra quiet setup. I am buying 16 pwm fans and would like to run them all off. Single pwm header & pcb controller.
The thermaltake can supply power to 10 and the design works really well with my wiring so my question is, does anyone happen to own one/know if i can run a 1 pwm to 2 fans splitter cable on this to potentially give 20 fans, although i will be limited to 16? Pcb looks to simply share the sata power to the headers & split the pwm signal between them all so concerned aboit the pwm signal over so many cables degrading to ****e.
Tvm in advance.
Tvm in advance.
