Hi,
We have decide to start listing a couple of the Thermaltake range to give you guys a couple more options when looking for upgrades or a complete rebuild.
We have 2 coolers and a selection of fans for you to take a look at.
ThermalTake Riing Silent 12 Red CPU Cooler @ £39.95 inc VAT https://www.overclockers.co.uk/thermaltake-riing-silent-12-red-cpu-cooler-hs-041-tt.html
Compatibility, Intel LGA 2011-3/2011/1366/1156/1155/1151/1150/775,AMD FM2/FM1/AM3+/AM3/AM2+/AM2
Specification:
- Dimension: 159 x 140 x 74 mm (H x W x L)
- Fan Dimension: 120 x 120 x 25 mm(L xW x H)
- Fan Quantity: 1
- Fan Speed: 500~1400 RPM - 300~700 RPM (with LNC )
- Air Flow: 53 CFM
- Acoustical Noise: 18 ±1 dBA, 13 ±1 dBA (with LNC)
- Pin Connector: 4 Pin PWM
- Cooling Power: 150 W
- Weight: 825 g
Only £39.95 inc VAT.
ORDER NOW
ThermalTake Riing Silent 12 Blue CPU Cooler @ £39.95 inc VAT https://www.overclockers.co.uk/thermaltake-riing-silent-12-blue-cpu-cooler-hs-042-tt.html
Specification:
- Fan Quantity: 1
- Air Flow: 53 CFM
- Weight: 825 g
ORDER NOW
ThermalTake Riing 120mm 12 LED RGB 256 Colors High Static Pressure Radiator Fan @ £19.99 inc VAT https://www.overclockers.co.uk/ther...h-static-pressure-radiator-fan-fg-003-tt.html
Riing 12 LED RGB 256 Colors High Static Pressure Fan, 120mm, 800 - 1500 R.P.M, Max 26.4 Db
Specification:
- P/N: CL-F042-PL12SW-A
- Started Voltage: 9.0 V
- Rated Voltage: 12 V
- Rated Current: 0.21 A
- Power Input: 2.52 W
- Fan Speed: 800 ~ 1500 R.P.M, 400~1000 R.P.M (Low Noise Mode)
- Max. Air Pressure: 0.57 ~ 2.01 mm-H2O
- Max. Air Flow: 22.14 ~ 40.6 CFM
- Noise Level: 18.5 ~ 26.4 dB-A
- Bearing Type: Hydraulic Bearing
- Life expectation: 40,000 hrs,25c
- Connector: 4-pin PWM (Controller To M/B), 2510-5P ( Fan To Controller )
- Weight: 161.1 g
- LED Light: Red -> Blue -> White -> Green -> LED off -> 256 colors
Only £19.99 inc VAT.
ORDER NOW
ThermalTake Riing 140mm 12 LED RGB 256 Colors High Static Pressure Radiator Fan @ £21.99 inc VAT https://www.overclockers.co.uk/ther...h-static-pressure-radiator-fan-fg-004-tt.html
Riing 12 LED RGB 256 Colors High Static Pressure Fan, 140mm, 800 - 1400 R.P.M, Max 28.1 Db
Specification:
- P/N: CL-F043-PL14SW-B
- Fan Dimension: 140 x 140 x 25 mm
- Rated Current: 0.26 A
- Power Input: 3.12 W
- Fan Speed: 800 ~ 1400 R.P.M, 600~1100 R.P.M (Low Noise Mode)
- Max. Air Pressure: 0.515 ~ 1.58 mm-H2O
- Max. Air Flow: 29.229~ 51.15 CFM
- Noise Level: 19 ~ 28.1 dB-A
- Weight: 191.6 g
Only £21.99 inc VAT.
ORDER NOW
ThermalTake Riing 12 High Static Pressure Blue LED Radiator Fan @ £15.95 inc VAT https://www.overclockers.co.uk/ther...pressure-blue-led-radiator-fan-fg-002-tt.html
Thermaltake PC case Fan, 120mm, Blue LED, 3 Pin Connector
Specification:
Dimensions: 120 x 120 x 25 mm
Fan Speed: 1500 R.P.M
Max Air Flow: 40.6 CFM
Noise: 24.6 dB-A
Connector: 3 Pin
Only £15.95 inc VAT.
ORDER NOW
ThermalTake Riing 12 High Static Pressure Red LED Radiator Fan @ £15.95 inc VAT https://www.overclockers.co.uk/ther...-pressure-red-led-radiator-fan-hs-043-tt.html
Thermaltake PC case Fan, 120mm, Red LED, 3 Pin Connector
ORDER NOW
Specification:
- Dimensions: 120 x 120 x 25 mm
- Fan Speed: 1500 R.P.M
- Max Air Flow: 40.6 CFM
- Noise: 24.6 dB-A
- Connector: 3 Pin
- Weight: 158g
View our entire fan range here
View our entire cooler range here
Specification:
- Fan Quantity: 1
- Air Flow: 53 CFM
- Weight: 825 g
ORDER NOW
Specification:
- Fan Quantity: 1
- Air Flow: 53 CFM
- Weight: 825 g
ORDER NOW
Specification:
- Weight: 161.1 g
ORDER NOW
Specification:
- Weight: 191.6 g
ORDER NOW
Specification:
Noise: 24.6 dB-A
Connector: 3 Pin
ORDER NOW
ORDER NOW
Specification:
- Noise: 24.6 dB-A
- Connector: 3 Pin
- Weight: 158g
