Thermaltake core P5 2018 Build
10 Jan 2016
Tyne & Wear, UK
just thinking of a new build pc gaming rig for next year, at the moment im looking at the following hardware just looking for peoples views on what im choosing budget approx £2600
Intel core I7 7700k 4.2ghz
Corsair Hydro Series H115i (CPU Cooler)
Asus ROG Maximus IX Hero
Corsair Vengeance RGB, 32GB, DDR 4, PC4 - 21300
Asus GTX 1070 ROG Strix 8GB
Corsair Hydro H105 (GPU Cooler)
NZXT Kracken G12
Windows 10 64bit
Corsair 240 GB Force MP500 SSD
Intel 32GB Optane Memory
Corsair RM1000X PSU
Asus Strix Raid Pro 7.1 Sound Card
Thermaltake Core P5 case
Thermaltake Core P5 AIO Brackets
Asus SBC-06D2X-U External Bluray Combo Drive
Corsair Commander Pro
Corsair Lighting Node Pro
Asus PCE-AC68 Wifi card
Corsair SP120 RGB
Purchase time will be around April to August 2018,
There are several addons for this case and motherboard im looking at the moment
(to be added after initial build)
m.2 cooler for the motherboard & atx power cover for motherboard
5.25" bay for the case & side fan mounts for the case
but i dont know anyone with a 3d printer,
if anyone has any thoughts on the spec id love to hear them
its dangerous to span your build over such a long period of time - more for the fact you'll change your mind over and over and then rumors of tech coming out will slow you down etc etc
I see your going for the Strix with kraken , any reason for choose on flagship brand to cool with AIO kits? Same can be said for me as I have the same card but Phanteks waterblock with allows the backplate to be kept and cards RGB to be use don the block you'll lose all of this with the kraken, not sure if you'll have to remove the backplate for it . Plus you'll void your warranty with Asus for cooler removal .
My basket at Overclockers UK:
Total: £828.88
(includes shipping: £9.90)
[/b]
Both brands support cooler removal
You might get swayed over by Strix X299 if the CPU pricing is good ;)
