Thermaltake Level 10 Case! The proper one!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
We have aquired the last 3 units of these Level 10 Cases! These are the original modular case which are designed by BMW!
Thermaltake VL30001N1Z Level 10 Case - Black @ £399.98 inc VAT
The "Level 10" concept allows gamers to experience the power of their high-end computers through the design itself. In order to achieve this, iconic design is combined with optimum functionality and innovative details. By rendering the inside components visible, the design concept focuses on the architectural aesthetics which are inherent in the computers and result from each individually configurable component. The inspiration for this approach the deisgn team took right from the computer worlds themselves - expressiveness, virtual townscapes and futuristic game components served as orientation for the arrangement and the look of individual components. These appear within the overall design in the form of an open modular structure that visually appeals to users, offering additional functional benefits.
- Co-Designed by BMW
- Case Type: Full Tower
- Dimension; 666.3 x 318 x 614 mm (H x W x D)
- Material: Aluminum
- Front Cooling (intake): 140 x 140 x 25 mm Red LED Fan, 1000rpm, 16dBA or 120 x 120 x25 mm fan
- Rear Cooling (exhaust): 120 x 120 x 25 mm Red LED Fan, 1300rpm, 17dBA
- HDD Cooling (intake): Dual 60 x 60 x 15mm Silent Fan, 2500 rpm, 19dBA
- Drive Bays 9 (3 x 5.25") (6 x3.5" removable tray drive bays)
- Expansion Slots 8
- I/O Ports: USB 2.0 x 4, eSATA x 1, HD Audio x 1
Was £514.99 Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
If you're after a more value priced offering
Thermaltake VK60001W2Z Element S Case - Black @ £59.99 inc VAT
Silent, cool and stylish are the hallmarks of a classic case. The Element S hits the mark on every level; featuring large quiet fans to maintain maximum airflow, anti-vibration and noise material is applied to the side panels, stealth black interior shows off the quality both inside and outside and when combined with excellent build quality makes the Element S the best Thermaltake case ever.
- Anti-vibration & noise reduction materal on side panel
- Stealth Black Interior
- Direction-free HDD cage
- Excellent thermal performance with optimal air flow
- Folding edge design to strengthen structure and prevent cutting
- Front (intake): 120 x 120 x 25 mm TurboFan, 1300 rpm, 17 dBA : 120 x 120 x 25 mm (optional)
- Rear (exhaust): 140 x 140 x 25 mm TurboFan, 1000 rpm, 16 dBA
- Top(exhaust): 230 x 230 x 20 mm red LED fan, 800 rpm, 15 dBA
- VGA (exhaust): Two 60 x 60 mm fan (optional)
- Drive bays: 3 x 5.25" and 7 x 3.5"
- Dimensions: 540 (H) mm x 230(W) x 505(L) mm
Was £83.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
I also think it's a cool looking case.
What's the differences between the one that's half the price? Not designed by BMW but made in the same factory in the middle east?
good work AceModder
I loved building systems in these. It was so easy to make a system look neat and tidy.
I have the Level 10 GT and its amazing - not as nice as the original Level 10, but so much space, really great airflow and it just looks good with the Thermaltake coloured led fans. I have it sitting sideways on a high shelf and love it. Would be tempted by the aluminium original though......hmm......
