Thermaltake Level 10 GT Snow Side Fan Noise
2 Feb 2012
Hi so I brought this case from Amazon warehouse for £85 to replace my Coolermaster HAF 922 and I fitted in everything to it but my question is that the side fan seems to be much louder than the two other 200m fans on the system. I have checked the specs and they all operate can the same levels.
When running the fans in low speed mode you can tell that near enough all the noise is coming from the side fan and when opening the side panel (which switches off the side fan) confirms this as the system goes dead silent and when putting the fans in high speed mode it's far more noticeable.
If anyone else has this case case, is yours the same as if not I can send it back within 31 days. I want to try avoiding sending it back as I love the style of it.
Thanks
