Thermaltake Level 10 GT Visionary Full Tower Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Thermaltake Level 10 GT Visionary Full Tower Case - Black @ £219.98 inc VAT
Following the high-profile launch of Level 10 Super Gaming Modular Case, the design collaboration between Thermaltake and BMW Group DesignworksUSA, in 2009, Thermaltake looks to invigorate the PC enthusiasts with the latest Level 10 GT computer case. The design language of the Level 10 GT expresses a passion for visual aesthetics deriving from demanding and immersive game play and multimedia entertainment enthusiasm. Modern games and entertainment applications also require highly advanced hardware configurations, which at the same time request more space and optimized ventilation than conventional hardware. With EasySwap Pitstop 5 every HDD/SDD has its own removable tray, EasySwap in hot-plug mode within seconds. With this users have greatest storage flexibility and maximum data transfer speeds you need. Modern multimedia peripherals operate at tremendous data transfer velocities, with 2 USB 3.0 connectors right on the top of the Level 10 GT you be guaranteed to always enjoy SuperSpeed entertainment. The concept of the clear lines of the outside design of the Level 10 GT is just as well continued in the inside. An advanced and highly convenient cable management bundles respective cables almost like in tunnels behind a back plate. Your system shines in clarity, easy access to all components is warranted for and even ventilation is greatly improved. High tech components are prone to heat impacting longevity and performance. For this vital reason the implementation of Thermaltake's QuadFan (of which three also feature ColorShift) Ventilation concept creates an ideal environment for your components to unfold their full potential. Perception of what and how it is surrounding us, can have strongly inspiring, motivating and vitalizing effects on us. With triple ColorShift three LED fans with five sets of illuminations let you get into the driver seat of your respective moods. Or if so wanted, you turn them all entirely. At times enthusiasm may push you to the ultimate limits, to where you have not been before. Particularly for those who are bound to go beyond these restrictions, i.e. tune and clock your setting, further measures to keep the heat down might be asked for. Ready for Liquid Cooling Systems you can rest assured to keep your coolness. Powerful performance needs space to unfold, this is also the case for highly advanced graphics cards, which the length has grown considerable over the past years and is most likely to grow even further in the future. With space for up to 37 cm oversized cards, there is sufficient space to stay future proof.
- Performance cooling made quiet: one top 200mm exhaust fan, one front 200mm intake fan, one side 200mm intake fan and one rear 140mm exhaust fan.
- Hinged side panel to enable easier opening of the side door and access to computer for maintenance or upgrade.
- Dramatically improved cable management. User no longer "hides" the excessive cable on the back, the Level 10 GT features numerous holders designed into the chassis for cable management.
- Five hot-swappable hard drive bays, each with its dedicated backplane to support hot-swap. Hard drive mounting supports both 2.5" or 3.5" drives.
- Connectivity array. Four USB 2.0 ports are conveniently located on the front bezel including a pair of audio ports. Two USB 3.0 ports and one eSATA port located on the top.
- Water cooling ready - 120mm or 240mm radiators can be easily attached to the top side of the chassis (top 200m fan needs to be removed)
- Fan speed management control embedded. ColorShift fans can be easily controlled through controls on the top.
- Fully black-powdered interior.
Only £219.98 inc VAT.
ORDER NOW
Pass. None of the radical design concepts that made the Level 10 cool, all of the ugliness. Oh, and the price.
Always good to see a diverse selection of products though.
£220. That's a bit steep. Surely this is at the sort of prices where you'd find top end entusiast cases such as Lian Li, Silverstone Fortresses and Corsair 800Ds. I thought OcUK stopped stocking Thermaltake cases because of their questionable quality.
Anyway why would someone buy this hideous thing?
Just my opinion though. If you like it then they are your eyes you'll damage.
Why would someone buy this hideous thing?
Just my opinion.
One can only assume that up to now money generally bought taste with cases (there aren't any really expensive but hideous cases), so Thermaltacky stepped in to fill the gap.
Well i think i will step in to defend this case a little bit as have now used 2 in builds. First up the build quality is very very good, the panels fit better than my Corsair 600t and are very strong. Second its easy to build in, great cable management and great cooling at stock so no having to add more fans also fans are very quiet even on high.
The only thing i dont like are the led fans but thats personal choice and strangely when you see it in the flesh it actually looks quite nice.
Anyway these are my own personal opinions but as the saying goes "dont knock it until you have tried it".
Cant say what its like to build in one, but the looks alone would put me off. But good to hear that its well made, something that thermaltakes lacked in the past.
My first case was a thermaltake tsunami dream, very poorly built. Switched it out for an akasa eclipse. The panels were very flimsy and the tool less pci clamp was so poor i had to remove it and use screws. Hopefully their products are starting to improve. I had one of the toughpower psu's, a great unit, very quiet. Only sold it on as i needed something with a higher output.
So the first one looked kinda nice/okay but was way way to expensive for what it was now they have gone for ugly shoe box but cheaper....
