Hi all,
I've bought a Level 20 XT case, and am mounting two EKWB CoolSteam XE 480mm Radiators in the top. I plan on setting these up with a Push-Pull configuration and will therefore be screwing in BeQuiet Silent Wing 3 120mm high-speed PWM Fans. Can anyone suggest/recommend a Fan Hub? I was looking at the EKWB Loop-Connect but I can't find the stock.
Regards
Regards
