Thermaltake M9
28 Apr 2004
19th Hole
I just got a Thermaltake M9 windowed case because the Thermaltake Aguila case I bought wouldn't take my Tuniq Tower and a window fan.:(
Also the PSU wouldn't fit in once the mobo + Tuniq were in.
The M9 is a smaller case than the Aguila but I can Have the Tuniq and a window fan; also the PSU will fit after the mobo and Tuniq:D
I really like the way the HDDs/DVD/Floppy drives can be fitted anywhere in the front. I have DVDs and floppy at the bottom (where the connectors are now placed on P35 Mobos) and HDDs towards the top. I also like the on/off and USB ports where the top DVD usually is. One problem is there is only room for 3 Hdds in the tray.
I like this and it was £20 less than the Aguila - are OcUK going to stock them?
