Thermaltake Sonic Tower
2 Sep 2006
Forest Grove, OR, 'Merica
Does anyone have this? Is it possible to add a 120mm fan?
My friend's Arctic Freezer just broke and he needs something cheap and good that doesn't use the crappy intel mounting system with the plastic pins.
This Sonic Tower can be had for 20 shipped so it seems like a decent deal (will be cooling an e4400)
I have it. It's a really good cooler if you add a fan in the middle and you use all powerful fans - the fins are close together so it requires loads of pressure to get good cooling. You can bend the pipes really easily and get a 38mm fan in the middle if you must.
It comes with two brackets so you can add a fan on either side but as it's quite a wide sink it'll get really close to your exhaust fan anyway.
In hindsight I'd have taken a ninja for £5 more or so. It's a nicer cooler with better temps and it works much better with lower speed fans.
Edit:// oh and the ninja comes with a fan too.
Thanks for the response but it turns out we were able to replace the legs on the Arctic Freezer
