coincidentally i just got mine on monday, VB1000 SWS, it is quite high build quality, tonnes of free space, felt much more roomy than my soprano, the side window is
HUGE shows off all your components, I can't coment on the usefulness of the supplied fans, as i pulled them straight out and fitted coolinks, but hey, it's 2x120mm and a 92mm on the side panel, so they can't do too bad a job,I had a little trouble fitting my x1900xt with the tooless expansion slot thingies, so i had to take that out, however, it does work for single slot expansions...as i tried the supplied coolink fan controllers, and it held them in place fine, got no cuts from the case, very roomy, although i had a little problem fitting my hard drives and my x1900xt (which is massive) this probably wouldn't be such a problem with smaller graphics cards. the clips for the HDD's and optical drives work fine aswell.
all in all i had quite an enjoyable build, no big problems with the case, just the large card issues, cooling inside is quite good, lowered my recorded temps on speedfan by 3-4 degrees.
good case for the money
edit: to comment on the front bezel, it does seem a little flimsey, but if you pull it open from the middle, and push it closed at the middle it feels fine, to be honested, i knew it was plastic, but really couldn't tell the difference before i touched it, they have done a good paint job, dunno bout the black one though
