Hello there,
I'm new to the forum but would be grateful for some of your experience to help with the below. I'm a computer enthusiast myself and love modding but work and life commitments have kept me from tinkering around for some time.
I have the Thermaltake Tai Chi VB5001SNA case with the in-built water cooling system. One of the hoses from the water tank to the CPU cooling block broke a while back and after struggling to find any hoses that exactly fit the existing ones and without any specifications to work off I decided to remove the existing system and replace it with one built myself. I've not started doing anything yet, as I'm also visually impaired and therefore don't want to do anything irreparable.
My questions are:
1. is there any guidance to be noted when removing the existing system, or do I just let rip with every screw I can find? the radiator seems to be the hardest to remove as I can't seem to locate some of the screws.
2. Can anyone advise as to a basic shopping list for what I need to purchase to put the new system together? I only want to go as far as the existing system, e.g. CPU cooling only, but I do want to ensure better liquid flow and use standard sized hoses.
Thanks in advance for any help and apologies also in advance for all my silly questions.
Best Wishes,
Hussein.
My questions are:
Best Wishes,
Hussein.
