I Chosen the Asus ROG Strix B760-G Gaming DDR5 due to Its Features, Colour & that the First PCI-E 16 Slot position on the board match's up with
with the first PCI Bracket on the Tower 200 case so the GPU will not be near the left hand side panel.
something to take note when you choose a Micro ATX Motherboard for the Tower 200.
update Added the 7800xt, No coil whine/Buzzing, Fans only spin at low RPM under load,
Sapphire Pure same Core Clock & Boost Clock as the Nitro + but only just over 2 slot Design & No RGB Glow tab to change the RGB in the Sapphire TRIXX Software.
