Thermaltake the tower 900
2 Aug 2017
hello is there anybody that can clear something up for me regarding this case as I've looked on the internet at reviews and pictures and can't see how your suppose to connect your display port lead or hdmi to your gpu as they are vertical and there is no cut outs in the top of the case or even the ports on the mobo obviously you can but I just can't see how
Thanks
Ok so I've now found a review showing these connections at the top of the case not sure I like the thought of a lead coming out the top , can't really hide that
I liked this case so much as well :confused:
i think the cable would be hidden underneath the top cover if these picks are correct
I am using this unit for a build for my grandson, I personally dislike it soo much but, he wants the thing. Had a lot of time on my hands with this had for couple of months waiting for threadripper build under water. The biggest problem is getting any pump and reservoir to fit and work other than thermaltake. Any more questions i will try and answer for you. but i am really fighting the prejudice against this case, Regards
Thanks for the info lionheart I think I'll give this case a miss as this is going to be a first build project so I want a case that will be easy to work with as I want to try a custom water loop I'm probably biting of to much for a first build but i like jumping in the deep end doing a good bit or research before I start
Thanks again
