Hi all
This is my 1st build for around 5 years or so and first time doing a amd build.
I like the look of the thermaltake tower case, but for where I wanted to put it, the tower 200 was just to big, so I went for the tower 100 and decided to have a mod and play with it.
I wanted a aio bigger than the standard 120mm fit, so I went external radiator.
when the standard side panel is on, it blocked half the air flow to the gpu, also it was only 1-2mm away from the glass.
To solve this I went with a diy 120mm fan wall. A nice bit of positive air pressure, the fans can just spin nice and slow, but with a good amount of air going in.
I tried one of them diy pc case filters, but it just blocked the airflow to much, so I raided the mrs sock draw and ''borrowed'' a pair of her tights. This lets lots of air in, but nice and fine to filer.
spec...
7800x3d
Thermalright AM5 cpu holder
Sapphire Nitro + 7900xtx
Asus Rog Strix B650E-I
G.Skill Trident Z5 Neo 64GB ddr5 6000 mhz cl30
Lexar NM790 4TB m.2 drive
Seasonic Vertex PX 1200
Nzxt Kraken Elite 280mm AIO
Artic MX-6
Corsair Commander core xt
Corsair icue AF140 RGB Elite (internal fans)
Artic P12 Max (6x side fans)
3.5 Inch data screen
13.3 inch 2nd display to show stats
Thermaltake tower 100
spec...
7800x3d
Artic MX-6
