thermaltake tsunami vs thermaltake shark
3 Jul 2005
well, I need a case which is a good overclocking case ie doesnt get hot, and it has to be quiet (i will be using quiet components) and it has to look good and be sturdy. out of those 2 cases which one fits my needs, thanks
I would take the Shark, looks aside it is built slightly better.
But between them they will both be as good/bad as each other.
Ultimately the factors for noise are your hard drives, fans and coolers. How you mount them, what speed they run at and the quality of the fans all affect the noise the case makes.
The front is much more durable, thats about it as Thermaltake front panels usually look the part but dont have the staying power of a comparable ATCS or Lian Li door.
What other cases have you considered?
thats all. Ive read the forums, i dont want the lian li- ERR *throws up* and I just like the idear of opening up the front panel etc. So I should get the shark case as the front is better, would the cooling be better as the case is bigger?
You never know how the cooling will be 100% until you put your rig in it, but the Shark is a good cooler from what people say, and it rates higher amoung owners of both.
Its a ok case all in all :)
(You knew I had to mention Lian Li ;))
I am making a new pc and i am using the shark case, here's a pic the case is al made very well and looks very nice from the out side! overall i am very impressed.
