Thermaltake Urban Cases! Landing tomorrow!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
A cool new range of cases are landing tomorrow. Only 10 of each. Initial stock is quite limited, but we have more arrived 2 weeks later. Grab one on pre-order if you are interested.
Thermaltake Urban S31 Midi Tower Case - Black @ £84.98 inc VAT
Urban S31 windowed mid-tower, categorized in Thermaltake latest chassis collection – Urban Series. The entire series has a simple and elegant aesthetic, design for users who looks for everything but a flamboyantly appearance. Built with brushed aluminum finish front door panel to mask the extrusive drive devices, combined with a windowed side panel, it is hard not to get attention on! The perforated front-top panel has implemented two of latest data transfer SuperSpeed USB 3.0 ports along with two USB 2.0 ports, a HD microphone and headset jacks, to grand direct access when needed. Top-mounted 2.5” or 3.5”HDD Docking Station enables blazing fast file transfer and effortless hot-swap drive replacement design for easy setup or removal of optical drives and HDD. Two preinstalled 120mm fans to optimize system ventilation in Urban S31. Plus pre-mounted hole for more ventilation options, users still can build up system ventilation by their preference. This case enables user to build up a complete high-end solution with ease with 240mm radiator liquid cooling system and extra long graphic card supported to protect user’s hardware and increase CPU’s overclocking potential, mostly importantly delivers outstanding cooling efficiency in the entire case.
- Case Type: Mid Tower
- Dimensions: (H x W x D) 500x 206 x 520 mm
- Net Weight: 7.3Kg / 16.1 lb
- Side Panel: Transparent Window
- Material: SECC
- Cooling System: Front (intake) : 120 x 120 x 25 mm Turbo fan (1000rpm,16dBA) / 120 x 120 x 25 mm fan (Optional)
- Rear (exhaust): 120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust) : (Optional) 120 x 120 x 25 mm fan x 2 or 140 x 140 x 25 mm fan
- Bottom (intake) : (Optional) 120 x 120 x 25 mm fan
- Drive Bays: Accessible : 3 x 5.25’’, 1 x 3.5’’ (Converted from one 5.25” drive bay)
- Hidden : 6 x 3.5’’ or 2.5’’
- Docking : 1 x 3.5” or 1 x 2.5”
- Expansion Slots: 7
- Motherboards: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, HD Audio x 1
- PSU: Standard PS2 PSU (Optional)
- CPU cooler height limitation: 155mm
- VGA length limitation: 290mm(with HDD rack) / 410mm(without HDD rack)
Only £84.98 inc VAT.
ORDER NOW
Thermaltake Urban S31 Windowed Midi Tower Case - Black @ £89.99 inc VAT
- Material: SECC
Only £89.99 inc VAT.
ORDER NOW
Thermaltake Urban S21 Windowed Midi Tower Case - Black @ £69.95 inc VAT
Urban S21 mainstream mid-tower, one of the members of Thermaltake newest chassis series with simple and elegant aesthetic; designed for users who looks for everything but a flamboyantly appearance. Using metal brushed front door panel to mask the extrusive drive devices, not only unify the appearance, but also provide a simple yet elegant aesthetic. The Front-top panel has implemented two of latest data transfer SuperSpeed USB 3.0 ports, a HD microphone and headset jacks, to grand direct access when needed. Preinstalled two 120mm fans to optimize system ventilation. Plus pre-mounted hole for more ventilation options. Pre-mounting holes to support motherboards up to standard ATX and CPU cooler installation, extra long graphic card also supported as well as rubber grommeted holes for Advanced Cable Management and Liquid Cooling System.
- Dimensions: 438 x 185 x 497 mm
- Cooling System Front (intake) :120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust) :(optional): 120 x 120 x 25 mm
- Side (intake) : (optional): 120 x 120 x 25 mm
- Bottom (intake) : (optional) 120 x 120 x 25 mm
- Material: SECC
- Hidden : 5 x 3.5’’ , 1 x 2.5’’
- I/O Ports: USB 3.0 x 2, HD Audio x 1
- PSU: Standard PS2 PSU (optional)
- LCS Upgradable: Supports 1/2”?3/8”?1/4” water tube
- Other: CPU cooler height limitation: 155mm
- VGA length limitation: 320mm
Only £69.95 inc VAT.
ORDER NOW
The urban s31 kinda has design takes from a certain silverstone case. Anyways I like the subtle design cues instead of the over designed, outlandish bringings they think everyone loves.
