Thermaltake VA8000SWA Armour Aluminium Super Tower - Silver (CA-006-TT)
Same thing with the fans.
The huge side panel fans are more of a gimmic than anything, been covered a fair few times on the forums but they should be silent pushing a fair bit of air but none of them do.
The point in going up with the fan size is to push the same amount of air or slightly more but at decreased volumes.
Yeh, the principle behind it is they should only be going 500rpm and pushing about the same as a YStech jobby does, but they dont push THAT much air for the size and noise they make.
The multiple user replaceable 120mm fan solution is by far the most efficent on the noise V cooling side, but if you want something with a bit of case bling then the huge fan is a huge gaming case draw I will admit, as the whole alien face thig was a while ago.
The 90mm will work with 92mm, it is just the outside of the screw size that Thermaltake are not measuring if I remmeber correctly.
Sorry if I didnt make it clear in my first post. :)
nah its ok, was just curious about the size of the damn thing :D
but might save up for Thermaltake VA8000SWA Armour Aluminium Super Tower - Silver instead then... well that or black... choices choices...
dont thermaltake do an all out window version of the side panel?
Mmmm i be tempted to try water cooling as a cool gimmick :cool:
