Thermaltake VA8003SWA Aluminium Armour
I personally don't have it i have a kandalf which is similar but search this case section there are a few threads made by people who love the case and the case itself is getting great reviews from customers and reviewers.
Its a great case, i would recomend getting a dremel and cutting squares on the mobo tray to keep wires tidy. Mine would have been tidy if ocuk sold the blue akasa cables in more than one size. But its allround a great case big enough to run SLI/Crossfire will fit 8800GTX/GTS fine ;). Airflow is good aswell.
my mate has had this case for a good time now, and has never doubted it. Only one problem occured when he built his new rig inside it, he bought that tagan 1100W psu and it wouldnt fit, all he had to do though is move some pins and a bar from the top, slide it in and place the bar back in.
youll see if you buy it.
ags
