Thermaltake VB5001SNA Tai-Chi SuperMidi Tower - Aluminium (CA-003-TT)
21 Oct 2002
Sol System
http://www.overclockers.co.uk/acatalog/Thermaltake.html
been thinking about this case , the one with the built in water cooling . thermaltakes website has links to lots of reviews singing its praises but i cannt seam to find any reviews that specifically focus on the watercooling system .
i was running asetek waterchill cpu/gpu on my previous build . But i had to mod the cpu waterblock ( cut away part of the plastic) to get it to fit my nf7-s mobo/barton 2500 . The waterblock now doesnt have the required part to fit an a64 mobo ! shortly before i upgraded my rig the seal on the waterchill reservior failed ( leaking blue dyed water over my carpet) . so im looking at a new waterblock and reservoir . or possibly this thai-chi system if i can find infor on the watercooling side .
anyone have a link to a rewiew of this case that includes investigation of the Wc side as well please let me know.
thank you
Google pops some up but I cant link as they are store sponsored. Ill have a look and see if I can get any that are not.
Generally the watercooling in the Tai Chi is about the same as high ish end air cooling, its quite a expensive way to go with watercooling.
