Thermaltake Versa C22 + OCZ stealth X stream 2
20 Mar 2011
I have the above psu and case, just putting my i7 bundle in it and have discovered that because the psu fits in the bottom of this case the psu leads arnt long enough for my gpu and at power connectors.
Can anyone recommend a decent psu 600w+ preferably modular that will support the Thermaltake case?
Tia!
Rather than replace a otherwise perfectly working psu you could just buy the cable extensions that you need. See here.
If you still want a new psu can you state your system spec please?
