https://www.thermaltake.com/view-51-tempered-glass-argb-edition.html
A look at it here in a CES video @ about 4.30
Looks interesting, a clear rip off from the Lian Li 011 Dynamic ( XL )
Have seen listed elsewhere in the UK for £169 release date 14/2/2020. 011D XL generally £189 ish with no fans.
Cheaper than Lian Li and looks like it comes with 2 x 200mm Front ARGB and rear 1 x 120mm ARGB.
Like the 011 supports bottom top and side, but also front rads , dont know if it can only be front or side but not both. 360mm max.
Looks like a similar rear drive bay to the 011D but probably not hot swappable connections.
Dimensions suggest more room than the 011D XL
011D (D) 471 x (W) 285 x (H) 513 mm
View51 550 x 315 x 525 mm
Was looking at the 011D XL but might hang on for this , anyone have any experience of Thermaltake copies and are they worth looking at ?
View 51 Specs
011D XL specs
View 51 Specs
P/N CA-1Q6-00M1WN-00
Series View
Model View 51 TG
Case Type Middle Tower
Dimension (H x W x D) 550 x 315 x 525 mm
(21.65 x 12.4 x 20.67 inch)
Side Panel 3 x Tempered Glass (4mm thickness)
Color Exterior & Interior: Black
Material SPCC
Cooling System Front (intake) :
2 x 200 x 200 x 30mm Addressable RGB fan
(Fixed 600rpm, 24dBA)
Rear (exhaust) :
1 x 120 x 120 x 25mm Addressable RGB fan
(Fixed 1000rpm, 27.2 dBA)
Drive Bays
-Accessible
-Hidden -Accessible
-Hidden">
2 x 3.5’’ or 2.5’’ (With HDD Cage) ; 2 x 2.5’’ (With HDD Bracket)
Expansion Slots 8
Motherboards 6.7” x 6.7” (Mini ITX), 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
I/O Port 1 x Type-C, 2 x USB 2.0, 2 x USB 3.0, 1 x HD Audio
PSU Standard PS2 PSU (optional)
Fan Support Front: 3 x 120mm , 3 x 140mm , 2 x 200mm
Top: 3 x 120mm , 3 x 140mm , 2 x 200mm
Rear: 1 x 120mm ,
Right: 3 x 120mm , 2 x 140mm
Bottom: 3 x 120mm
Radiator Support Front: 1 x 360mm , 1 x 280mm ,
Top: 1 x 360mm , 1 x 280mm ,
Right: 1 x 360mm , 1 x 280mm
Bottom: 1 x 360mm ,
Clearance CPU cooler height limitation: 175mm
VGA length limitation: 300mm(With Water Pump)
440mm(Without Water Pump)
PSU length limitation: 200mm
011D XL specs
BRAND O11Dynamic XL ROG Certified
MODEL O11DXL-X O11DXL-W O11DXL-S
COLOR Black White Silver
DIMENSION (D) 471 x (W) 285 x (H) 513 mm
MOTHERBOARD E-ATX/ATX/M-ATX/ITX (need to purchase an extension panel for EEB motherboards)
PSU 220 mm (max 280mm)
MATERIAL 1.0 mm ALUMINUM EXTERIOR
4.0 mm TEMPERED GLASS LEFT SIDE PANEL
1.0 mm SGCC INTERIOR
FAN 3 X 120 mm (side) + 1 X 120 mm (rear) + 3 X 120 mm/2 x 140 mm (base) + 3 X 120 mm/2 x 140 mm (top) (Optional)
GPU LENGTH 446 mm
CPU CLEARANCE 167 mm
DRIVES 10 X 2.5” SSD or 6 X 2.5” SSD + 4 X 3.5” HDD
EXPENSION SLOTS 8
I/O PORTS 4 X USB 3.0 (2 on the front, 2 at the front case feet), 1 X USB 3.1 TYPE-C, 1 X HD AUDIO
DUST FILTERS 1 X TOP, 1 X BOTTOM, 2 X SIDE
