Thermaltake watercooling thread
31 Oct 2006
Wiltshire / Winchester
Hey does anyone know what thread thermaltake use on their watercooling products? 1/8 or 1/4 or another type?
Cheers
6mm tubing with a pump that only pumps 90 l/ph max. Works out about the same as high end air cooling (did for me anyway) but it aint worth the money if buying new as the same temps can be had for half the price. Its ok as a starter kit if you are dubious regarding the setup with watercooling as a monkey can get it working tbh. Not recommended for high performance systems though, for that you should be looking at something more substantial such as a custom setup or the Apex ultra in kit form. I've done all 3 and the custom kit is the best option for performance but not if its a first time WC project - for that the Apex is more suitable. Hope this helps.
