Thermaltake Z-One 3600mhz won't run at rated speed
2 Jan 2014
I have 4x8gb(32gb) Thermaltake tough-ram Z-One which when I set my XMP is running at 2667Mhz speed. I have tried to set the speed manually changing the auto setting in my bios to 3600mhz but it causes some games to crash or give me memory management BSOD.
Is there anyway to get the ram to run at it's rated speed on the Asus Maximus formula X MB.
Motherboard ? CPU ?
Motherboard ? CPU ?
Motherboard ASUS Z370 Maximus Formula X CPU Intel coffee lake 8600K
I managed to sort it strangely I turned on the XMP the first time it did not work and I had to change the speed manually but I tried resetting and turned XMP on and it worked fine without any adjustments.
