- 23 Aug 2007
- Rothesay
I dont know where the best place to post this question would be.
As it is to do with Watercooling i thought here but it could equally be posted in the case's thread.
Ok on to my querry
I,ve got a Thermochill PA240 rad (25mm spaced one) and bought a rad shroud for it as well as a Fan Grill for the roof of my case.
Ive got that setup and attached via the 4 screws that come with it, and ive got the screws i require to attach the fans to the shroud and they just catch the mounting holes in the rad.
Now when i eventually cut the required hole in the roof of my Lian-Li A20 and mount the rad to the roof, the screws i have will again just be catching the holes in the rad.(I mounting it with the fans in pull config.).
My worry is will the 4 screws that attach the shroud be strong enough to hold the rad in place when attached and full of water.
I have done a test fit of the rad + fans + shroud + grill and all is tight as but im still a little worried.
Ok on to my querry
