Hi all
Just built my 1st watercooled loop (CPU Only).
On the ThermoChill PA120.3 Radiator , Thermochill recommend that the fans are setup in a pull config?
Anyone got any experience on a ThermoChill Radiator fan setup, should I leave as is now (Pull), put them on push or get another 3 and use push & pull.
I could leave until its running and check the temps, but while its still in bits, it would be easier to change now if anyone has any ideas on this.
I a using 3 x Scythe Kaze Jyuni 1900RPM fans.
Thanks for any advice
